engine running cold.
Old Oct 11, 2005 | 01:51 PM
jughead's Avatar
cold engine
Originally Posted by infidel
How could it not be passing though the heater core?
There is no valve in the heater line, only an adjustable door (bend door) in the ducting.
Coolant is always flowing though the heater core unless you've done something to stop it.
it is in an 82 1/2 ton with air. has a vacuum shut off valve to shut water off when air is on. i understand if air is off water does go through heater core. it runs cold if the valve is closed or open. i cant believe a hunk of cast iron is beating me. look guys i do appreciate all suggestions. i aint young and dumb just old and senile
Old Oct 11, 2005 | 02:21 PM
infidel's Avatar
I feel you are trying to fix something that isn't broken and will never have any luck with it.
Old Oct 11, 2005 | 07:45 PM
jughead's Avatar
cold engine
u may be rite and i thank u for the replies. either i win or lose. i will let u know either way. just a hard headed old man. there has to be a reason for this that i havent found.
Old Oct 12, 2005 | 10:06 AM
infidel's Avatar
Old man here also.
You'll have to admit that it's a heck of a lot better than not being able to find the cause of an engine that's running too hot.
Old Oct 12, 2005 | 10:57 AM
jughead's Avatar
cold engine
u are so rite. in the 40 + years i have been in the business this is the first one that has run cold. if it wasnt for my mother on cold mornings i wouldnt think about warming it up. now though it has become a challenge.
Old Oct 12, 2005 | 06:59 PM
infidel's Avatar
I live where it's much colder than you and no heater certainly becomes an issue.
I use a winter front and run with the fan removed for about seven months out of the year.
Using the recirc position on the heater control helps the most though.
builtnotbought1
Jul 6, 2014 09:49 PM
black&blue
Feb 18, 2009 08:32 PM
Common
Jul 27, 2007 09:29 AM
wcbcruzer
Aug 21, 2005 08:48 PM
wood_n_soldier
Dec 24, 2003 01:00 PM
