Engine dies
Old Sep 20, 2004 | 10:21 AM
nukeworker's Avatar
Unhappy Engine dies
The engine in my 1997 Dodge 2500 Cummins Turbo Diesel with Bank Power Pack has frequently started dying after cold startup. The truck starts normally, I let it run for a couple minutes, but when I pull it into drive and step on the throttle it dies. It may do this once, or several times, then runs perfect. I don't know if it is normal, but have noticed that after cold startup that every 15 seconds the ammeter shows a draw on the charging system that lasts 2 seconds. After warmup this does not occur. However, during one of the episodes when it died several times the ammeter showed a steady power draw. Any idea of the problem?
Old Sep 20, 2004 | 11:03 AM
apache's Avatar
The intermitten amp draw is from the grid/intake heaters. This is normal and lasts for a few minutes at least depending on outside temp. Stalling???
Old Sep 20, 2004 | 11:12 AM
SHARPMACHINE's Avatar
More than likely your idle is to low and increasing it will help it idle when it is cold outside. Do a search to find instructions on increasing your idle speed. Welcome to this sight .... it is great!!
justmy.002
Old Sep 20, 2004 | 11:14 AM
DieselDaze's Avatar
Welcome to DieselTruckResource (DTR) nukeworker, were glad to have you here.
Sound like it could just be something as simple as your idle being too low.
Also, there is a fuel return line that takes return fuel from the injection pump back to the tank. This is a rubber line that sneaks its way behing the block and is subject to cracks.
Just a couple ideas to check out.
The voltage draw is your heater grids working. This is normal for cold (outside) temps.
Rich
Old Sep 21, 2004 | 09:16 AM
nukeworker's Avatar
Should I expect to see a fuel leak if the return line is cracked? If the line is cracked is there a vacuum leak? The odd thing is the problem only occurs at cold startup.
Old Sep 21, 2004 | 09:35 AM
DieselDaze's Avatar
If the leak is bad enough, yes, you will see a diesel fuel leak.
However, it is my understanding that it really doesnt take much more than a small crack from dry rott to cause problems.
With such a small crack in the return line, you may notice the fuel leak by sight.
Ive replaced my return line and found it cracked, but never bad enough to cause a leak.
I'll have to defer to more experienced members to provide you a better answer.
Rich
vintovka
Apr 30, 2012 12:38 PM
90 power ram
Oct 6, 2011 08:04 PM
1ST CUMNZ
Jul 21, 2003 07:33 AM
joken
May 14, 2003 06:47 PM
joken
May 14, 2003 05:47 PM
