Engine compartment fire.
Old Jul 25, 2013 | 11:25 AM
deking1970's Avatar
My Dad's 1998 12 valve quad cab caught fire under the hood a month or so ago and he has almost everything working.
There are two problems though. We can't find where the vacuum line for the AC goes through the fire wall and the radio and interior lights don't work.
Fuses are good, and the wiring harness appears to be intact except one of the relays on the firewall is melted. Could that be the problem? Does anyone have an idea of where else to start looking?
Old Jul 25, 2013 | 04:54 PM
Busboy's Avatar
The vacuum line for the Ac is a small black plastic line that passes through the firewall with the AC fittings going to the evaporator, through the foam gasket. The Radio may be grounded through the antenna so if the antenna lead is burnt off it may not ground as well as no radio signal.
Old Jul 25, 2013 | 07:26 PM
gorms's Avatar
Alot of people overlook the IOD fuse in the left dash fuse box. It's usually inside a yellow holder, top left I beleive.
Old Jul 26, 2013 | 09:57 AM
deking1970's Avatar
Thanks gorms. You were right about the IOD fuse. What does IOD stand for? We are still trying to find what is left of the vacuum line.
Old Jul 26, 2013 | 11:41 AM
infidel's Avatar
IOD = Ignition Off Draw
Vacuum line passes though the firewall in the turbo area.
Old Jul 26, 2013 | 06:07 PM
Busboy's Avatar
The factory vacuum line is hard enough you could just get another piece and stuff it through at the fittings then splice it in under the dash to the existing black line.
Puke
May 8, 2007 10:04 PM
tobyw
Aug 2, 2006 01:55 PM
pianotom
Jun 15, 2005 03:34 PM
MK4288
Jun 22, 2004 11:38 AM
