engine brake
Old Nov 26, 2010 | 06:13 PM
Skip H's Avatar
engine brake
Has anyone tried to using the fuel cutoff solenoid for engine braking?
Could it be done?
Old Nov 27, 2010 | 10:12 AM
Clayten's Avatar
DTR's Toad Wrangler
No and no
Old Nov 27, 2010 | 12:14 PM
torquefan's Avatar
Not sure if this would help slow the vehicle or not, but the big problem is that with a P7100 pump, the shutoff solenoid has a separate circuit to pull up the solenoid. Basically you wouldn't be able to simply switch power off and on to the solenoid with a toggle switch as you desire. You have to actually re-engage the starter to pull up the solenoid.
Old Nov 27, 2010 | 03:56 PM
gorms's Avatar
Pump doesn't use any fuel until close to idle anyways with foot off the pedal, i.e. downshifting.
Old Nov 28, 2010 | 05:54 PM
rebal's Avatar
Could it be done?
US Gear uses one on there 12volt model engine brake I have one on a 2001
it needs a controller to lower power to the solenoid or it will burn up
Old Dec 1, 2010 | 05:47 PM
Skip H's Avatar
If you turned off the fuel when going down hill, wouldn't the 17 to 1 compression slow down the vehicle or am I dreaming?
TIA
Old Dec 1, 2010 | 06:42 PM
Andy505's Avatar
TIA
Without an exhaust brake it wouldn't do any more than letting off of the throttle.
Old Dec 1, 2010 | 07:39 PM
Tate's Avatar
TIA
You still have all the air thats now been compressed pushing back down on the piston. It acts as a spring. You'd need to vent it at close to TDC, like a jake brake, for that to be effective.
Old Dec 2, 2010 | 06:59 AM
G1625S's Avatar
Exactly Diesels have no inherent retarding power which is why engine brakes and exhaust brakes exist for them. Think of a gasser, when you let off the throttle, the butterfly closes and that tends to give some retarding power. An exhaust brake on a diesel is a similar concept, only the butterfly is on the exhaust rather than the intake. Tate, I really like the 'spring' analogy
Old Dec 2, 2010 | 09:45 PM
cj360trider's Avatar
most all of the Exh Brake applications I see are for Standard trans only...do they not make one compatible with an Auto? I worked for fuso a few years back and all of their trucks auto and standard had them. i wud think all youd need to work out is how to lock up the TC to make it effective. with these trans' you may only be able to use them in 3rd and OD
Old Dec 3, 2010 | 11:03 AM
infidel's Avatar
PacBrake sells a auto tranny controller that locks the TC so their brakes work on an auto or a person can do it manually with a simple lockup switch.
Old Dec 4, 2010 | 09:55 PM
KKRRSS's Avatar
Yep, BD lockup switch on mine with pacbrake.
Old Dec 5, 2010 | 12:39 PM
rebal's Avatar
yup, lock up switch/valve body that locks in all gears and a pack brake work great
rebal
0
May 7, 2011 06:33 PM
garr_trenching@
Jun 21, 2007 03:56 PM
Mopar440_6
Feb 11, 2007 10:50 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
