egt's
Old Jul 30, 2011 | 07:43 PM
dgarner1988's Avatar
egt's
whats a safe limit for egts when towing down the highway for a long distance?
Old Jul 30, 2011 | 08:05 PM
csa's Avatar
csa
i tow a small 6x12 enclosed .... going down highway im at 850 ish...its gettin up to speed that i can hit 1300 but when rpms go down egt goes down...ive been told 1350 - 1450 after that things melt
Old Jul 31, 2011 | 03:54 AM
Exekiel69's Avatar
Technically the limit is 1250f but many stop pushing it before and even after it get to that temp.
Old Jul 31, 2011 | 08:42 AM
John_P's Avatar
The general unwritten rule on EGT's is no more than 1,300 degrees if the pyrometer probe is in the exhaust manifold and 1,000 degrees if the probe is in the downpipe AFTER the turbo.
John_P
Old Jul 31, 2011 | 09:09 AM
Ok thanks for the help, i will be pulling my 35ft camper to the mountain and was wanting to keep it in the safe range its a 4hr ride from here, so i was wanting to see what temp is safe to hold on constant going down the highway?
Old Aug 1, 2011 | 09:56 AM
infidel's Avatar
You also have to consider how much you trust your gauge.
I try not to exceed 1100° for extended periods even though I've been told you can cruise at 1250° all day.
Old Aug 1, 2011 | 06:37 PM
lechon's Avatar
egt's
hi everyone,
sorry to hijack this thread..? but since we're discussing egt's...
is it necessary for me to have an egt guage installed? i rarely tow and if i do, it's limited to a small single axle trailer with a small 4 cylinder car on it..the size of a toyota corolla. the longest trip would be from the san francisco area to los angeles.
i have a '96 cummins ram 5 speed with 184k miles on it.
thanks!
Old Aug 1, 2011 | 08:34 PM
John_P's Avatar
Originally Posted by lechon
hi everyone,
thanks!
lechon:
Let me start off by telling you "Welcome To DTR!" Glad to have you aboard as a Member.
You are not "hijacking the thread" either as your question is about a gauge with reference to EGT's so don't worry about that either! With reference to your question, I would tell you that I think a pyrometer is an important gauge to have, even if the truck is stock. The first thing I have done on all four (4) of my Dodge Cummins Diesel Pickups was to install a full set of gauges before I do anything else. But, that's me. The pyrometer is pretty easy to install and IMO gives you a good reference to engine heat to avoid damage to the engine.
Anyway, welcome aboard!
John_P
Old Aug 1, 2011 | 09:22 PM
lechon's Avatar
egt's
Hi John,
Thanks for the warm welcome and your tip on pyrometers. I will go ahead and have one installed on my truck.
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Hummin Cummins
Mar 20, 2003 07:20 PM
