EGT temp low?
Old Dec 10, 2007 | 08:06 AM
heykw's Avatar
EGT temp low?
my 98 will only hit 700 deg pulling a hill will the mods in my sig what gives and what should I do next?
Old Dec 10, 2007 | 08:20 AM
Dartmouth 12V's Avatar
Is your probe pre or post turbo?
Even if it is post, that sounds way too low. Your highway cruising egt's should be somewhere in the 600-750 range assuming that the probe is pre turbo. Have you checked all of your connections? I would suspect that it has something to do with the egt gauge, box, or probe rather than the rest of your truck unless it is being a real dog.
Old Dec 10, 2007 | 12:39 PM
C2O's Avatar
C2O
with the 215's and 181's, you have the ability to hit 1600. yours does seem low.
Old Dec 10, 2007 | 04:11 PM
heykw's Avatar
Pre-turbo probe, it must need more fuel. If the timing jumped would show low egt?
Old Dec 10, 2007 | 04:22 PM
crabbelle's Avatar
I would check you probe, i can hit 1000 pretty easy and i only have a fuel plate and cranked star wheel.
MossyOakCTD
19
Dec 28, 2010 09:11 PM
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
