Driveline slack
Driveline slack
I have a case of driveline slack, much more than most vehicles I've driven.
I can drive it pretty smoothly - but I know it would be a whole lot nicer to drive without the slack. If you don't know how to drive it, the slack can cause bucking quickly - which is absolutely terrible for the driveline.
I've got the NV4500 to the transfer case, and a Dana 80 in the rear.
Any ideas? I imagine the 5 spd and 80 are fine, so perhaps the transfer case? What loosens up to give slack?
I would think that, except it doesn't have anything to do with power applied... it just feels sloppy at low output torques. You feel the slack if you coast from engine powering to engine braking. Or vice versa... I would imagine axle wrap would be occuring under higher torque loads (than basically nil).
I should probably just dedicate an hour to crawling under the truck and trying to rotate the hell out of everything, and see what turns. I can't imagine the u-joints would be worn enough to cause that much slack, though there are 3 of them down the shaft, and everything does add up.
I hope it isn't in the differential - that would suck.
If I have the driveshaft off, I may as well put the transfercase saver in.
I'll probably stumble upon something that is ridiculously loose at some point, and shake my head for not finding it earlier.
If I hold the output shaft on the 5spd, and rotate the input shaft theres some play between when it engages the output shaft, but I don't think thats gonna cause what ur talking about because the flywheel is always moving so it won't cause slack unless it's from a stop and u engage the clutch, but thats not ur problem, i'm pretty sure ur's has somthing loose between the transfercase and the axle...
Put the t case in neutral and grab the drive shaft see how much slop you have in the rear end and u joint then put t case back in gear check the front u joint if at this point you have not found the problem check bolts as Infidel said . Still did not find it drop the rear u joint and turn the shaft to check for slop in t case
Thanks for all the suggestions, guys!
I was hoping there was one thing that everyone had difficulties with (replace this $4 part, and it'll work great!), but I'll just mill around under the truck and go through everything suggested.
Certainly, it will be a buildup of slack in a a bunch of components, but if I can tighten up the worst offenders, I should be able to make it a whole lot better!
I have quite a bit of slack in my spider gears in my D80. I am just living with it for now. I replaced the spider gears in my Mom's 92 (D70) several years ago, and it had slack within 6mo, so I am not too concerned about it.
Daniel
Daniel
hovisimo
Apr 28, 2013 01:29 PM
beardedone
Nov 21, 2008 05:44 PM
