Dripping oil, but only after hard boost
Old Aug 11, 2008 | 01:48 PM
lgp9999's Avatar
Hey guys, I'm having problems with crankcase pressure. Oil is being pushed through some various gaskets, but only after heavy boosting. Normal around town driving (I try to keep it under 8psi while accelerating usually, just for fuel economy) I never have any drips. Any ideas? I have no vacuum leaks.
Old Aug 11, 2008 | 06:05 PM
dozer12216's Avatar
Have you heard of blowby under load. It is the first indication of worn rings. As load increases gasses get past the rings at a greater rate. Cummins has a load test that measures blowby volume as indications of need to overhaul. It does not cure itself without dollars and labor input. Compression in a can will not fix.
Old Aug 12, 2008 | 10:44 AM
lgp9999's Avatar
Well that's what I was afraid of... boy does that put a not in my stomach.
Old Aug 12, 2008 | 01:13 PM
lgp9999's Avatar
Well I've begun looking around, and it seems that my best option is to get a short block to rebuild. Are there any blocks to avoid besides the 53 block? 1st gen blocks are the same, right?
Old Aug 12, 2008 | 01:26 PM
turboman1's Avatar
As far as I know there is only the 53 block on 24valves engines. Where exactly did you find the short block at?
Adam
Old Aug 12, 2008 | 01:42 PM
lgp9999's Avatar
It was in Texas per a friend and I called to see how much it would cost to ship it and they had already sold it. I've got a few other trees to bark up though.
Old Aug 12, 2008 | 04:43 PM
lgp9999's Avatar
I read that valve stem seals coming off can also cause excessive crank case pressure. Is this common?
Old Aug 14, 2008 | 05:31 PM
logskidder's Avatar
It has been for me
Old Aug 15, 2008 | 01:28 PM
lgp9999's Avatar
Well my front valve covers are the biggest leak source, so I'll check into that then.
075point9
Dec 24, 2012 12:24 PM
LUKE-MM-PULLER
Oct 31, 2010 09:35 AM
FirstDodge
Dec 31, 2006 02:38 PM
truckjunkie
May 20, 2005 11:42 AM
