DRAIN PLUG SIZE
Old Aug 9, 2003 | 03:22 PM
JARHEAD's Avatar
DRAIN PLUG SIZE
Just wondering if anybody knows what torx head fits the drain plug?? t-50, t-55, t-60, t-65???? This is on my '97.
Thanks!!!
Old Aug 9, 2003 | 10:42 PM
1dslram's Avatar
Re:DRAIN PLUG SIZE
What torx? None of the stock or aftermarket plugs that I know of use a torx for the pan plug.
Bruce
Old Aug 10, 2003 | 01:11 PM
JARHEAD's Avatar
Re:DRAIN PLUG SIZE
Mine does. may be aftermarket. I usually use a heavy equip. shop for oil changes but have moved. Guess i will probably just go and buy the entire set, should have done it years ago!!
Old Aug 12, 2003 | 02:18 PM
JFellman's Avatar
Re:DRAIN PLUG SIZE
My 97 has a drain plug that loosens with a 3/8" square drive ratchet. By the way, does anyone know if the drain plug will loosen easier when cold than when warm? Mine seems to have "self tightened" like so many others have experienced....put a lot of loosening torque on it just now and it wouldn't budge...waiting for it to cool down some before I try again. Last time I changed oil it was a lot tighter than I remember torquing it to also. I'm going to try a different plug this time.
Old Aug 12, 2003 | 03:33 PM
Mostwanted's Avatar
Re:DRAIN PLUG SIZE
try a breaker bar. I have twisted a couple of cheap 3/8 extensions and ratchets :'(
Steve034x4
Dec 12, 2005 08:21 AM
03CTDCO
Jun 15, 2005 11:11 AM
trik396
May 31, 2005 05:09 PM
cpermd
Oct 28, 2002 02:19 PM
