Downpipe Install ?
Old Feb 16, 2009 | 07:18 AM
Wicked500R's Avatar
Question Downpipe Install ?
I will be installing a new 4" system this week. The 2 downpipe bolts are in bad shape and I can see them snapping trying to remove them. Does anyone know the size of these bolts so I can have a couple ready to go.. Thanks!
Old Feb 16, 2009 | 07:58 PM
12v rollincole's Avatar
sorry i dont know the size of the bolts. i dont know how you plan on taking the down pipe out but i would pull the v-band clamp off from the turbo elbo and just take the down pipe with the elbo on it out in one peice so that you can get so WD-40 on the 2 bolts and get a good angle/grip to get them off, maybe without breaking them, that what i did when i installed my system and it was a lot easyer then trying to undo those bolts when the down pipe is in the truck + i didnt break the bolts .
so if you cant get new bolts you might beable to use your old ones if you have to.
Old Feb 16, 2009 | 08:03 PM
Wicked500R's Avatar
That's what I plan to do... I will have plenty of PB blaster and my torches ready to go...
Old Feb 16, 2009 | 11:04 PM
Tate's Avatar
10mm, roughly 60mm long. I know my MBRP system came with new bolts, I'd think most systems would.
Old Feb 17, 2009 | 08:39 AM
smokeyram's Avatar
mine did not come with new bolts, and naturally one snapped off removing it. on the side that broke, i drilled it out, put a through bolt in and lock washered it. ive checked it each time ive changed fluids and nothing loose yet.
PapeCAT
Mar 2, 2010 07:41 PM
97catintenn
Jul 12, 2009 05:33 PM
Fernando
Jan 24, 2008 03:32 PM
97CTD
Feb 4, 2003 03:05 PM
patriot pearl blue
Dec 15, 2002 12:10 AM
