Dowle Pin got Me
Old May 24, 2007 | 06:03 PM
txdodge97's Avatar
Dowle Pin got Me
I was driving home last night and it fell out got home looked under the truck and oil was all over the place. Went and got parts this morning and have the whole front end torn down just need to pull the gears. Well im going to go ahead and set my timing now. The pin took a thick piece out of the case and sat there rolling on the gears didnt mess any gears up though thank god.
Old May 24, 2007 | 06:14 PM
GAmes's Avatar
If you were thinking of an after market cam, now would be the time to get it.
Old May 24, 2007 | 06:23 PM
xzaq103's Avatar
It happened to me about six months ago. a friend was using my truck he calls me and says man you have a bad oil leak. I said I do. turns out it just cracked the timing case next to the pin. Bad thing is the tab I bought was in the mail....
Good luck man
Chris
Old May 24, 2007 | 06:32 PM
b.lee's Avatar
i gotta get my rear in gear and take care of my KDP.
Old May 24, 2007 | 06:34 PM
Dr. Evil's Avatar
Originally Posted by b.lee
i gotta get my **** in gear and take care of my KDP.
I definitely sleep better at night (and at work for that matter... ) knowing mine is done.
Thanks Marc.
Old May 24, 2007 | 06:45 PM
JKM's Avatar
JKM
Hmm , been putting it off for a year and a half , maybe I should get my rear in gear this weekend.
P.S. , I need a new line of work , there is jobs that let you sleep at work?
Old May 24, 2007 | 06:46 PM
Dr. Evil's Avatar
shhh, dont tell anyone....
J, check out the links on www.dodgeram.org
Old May 24, 2007 | 09:40 PM
ratsun's Avatar
You mean there are jobs that don't?
Old May 24, 2007 | 10:03 PM
gyman98's Avatar
Ya I put off doing mine too, cracked my case but I fixed it all with alot of time and effort for the cost of a front seal which was shot anyway
Old May 25, 2007 | 02:42 AM
Kemble's Avatar
I was told that my truck was tabbed, Never bothered to check for myself and one day it bit me in the rear. KDP came out and busted the case. Now I have a new case, and every gasket associated is new. I would highly reccomend checking for yourself if the PO says it is tabbed.
But for everyone else, It doesnt take much time to tab it and is way more cost effective .
Old May 25, 2007 | 05:18 PM
GCSS's Avatar
KDP secured
Jim Jessup did mine and it was like $150 total. He was fast too.
He has a timing cover all cleaned up and ready to go. He will swap out with yours and use yours on the next job. He is fast and neat as a pin. If anyone is in the southern Indiana area and needs a KDP to be killed, or repairs after the fact,call him at 812-873-7618........
Tell him Dave in Kentucky sent you.
Hope I helped someone out today!!!!!
Hammer down!!
Old May 25, 2007 | 05:50 PM
GAmes's Avatar
$150 to buy the gaskets, pull off the front bumper, A/C condensor, radiator, intercooler, front of engine, injector pump, vacuum pump/power steer pump, pull the cam replace the housing, reassemble and re-time. That is what I call CHEAP labor
You don't mind if I throw up the BS flag do you?
Old May 25, 2007 | 05:55 PM
sawmill's Avatar
If the front case gets busted can it be welded? It would alot cheaper than buying a new one.
Old May 25, 2007 | 07:52 PM
electrifried's Avatar
You can put the BS flag down. He is right on that one. You are talking about a guy that helped design these engines, then went across the US training mechanics how to work on them. He replaced my power steering pump on the 99 with a Cummins pump for $250.
His shop is clean enough to eat off the floor. Tools are laid out in perfect order. He set the timing on a 12 valve while telling me about his last fishing trip and had the job done before I even knew what He was doing.
Old May 25, 2007 | 09:20 PM
GCSS's Avatar
Yes the floors and benches BOTH shine. No bumper removal here..just the fan and belt,balancer, cover , and then secure the pin and reassemble.
Jim is the best there is. I had him soup up my truck too........I drive like fuel is free and get 19 city hwy, with some sense, I get 22, and then on the hwy I get 25-26 MPG.
Jim is the ACE in the Cummings dept.
The Cummings service manuals ???? Jim WROTE them.
It is simply amazing that anyone can even go to him in the first place.
Got to go........................
GCSS
