Does this soud like a blown headgasket
Old Sep 13, 2004 | 08:51 PM
TXram's Avatar
Hey all,
Here is the situation as I can best describe regarding my 97 3500. I am now possibly consuming water, I have smoking from my truck at idle. Truck will spew water from overflow, and I notice it worse when I am working the motor and making more boost. Good thing is I don't have any cross contamination issues. Is it resonable to assume that I most likely have a blown headgasket. If I do, what are recommendations regarding headgasket thickness, and any other recommendations.
Thanks All
Old Sep 13, 2004 | 09:11 PM
Forrest Nearing's Avatar
certainly sounds like it... sounds like you just sprung a leak to the coolant passage... I'd drain your oil or pull a valve cover and look for snot just in case.
get new head bolts from Cummins, have the head checked for damage/flatness and surface if necessary. if you cut .010" or less, use a .010" gasket, etc. etc.
Forrest
Old Sep 14, 2004 | 10:53 AM
BoostdCTD's Avatar
I agree with Forrest, it does sound like a bad headgasket because the air from compression is being forced back into the cooling system and vents out of the water bottle. I don't know of any other way this can be done without a bad headgasket.
Old Sep 14, 2004 | 05:16 PM
TXram's Avatar
Thanks, Guys
btown647
Mar 6, 2008 09:04 AM
Big P
Oct 18, 2007 04:17 AM
merr6267
Feb 4, 2007 03:44 PM
hottapper1
17
Nov 4, 2006 08:08 PM
caleb c.
Oct 12, 2006 04:25 PM
