Differential fluid capacity?
Old Jun 20, 2005 | 06:58 PM
CZSteve's Avatar
Another differential fluid question.
Going to changing the fluids in my Dana 80 (LS) and NV4500. Plan on using Redline.
75w90 (w/ friction modifier) in the rear and 50/50 of MT-90 & MTL the tranny.
Question: How much fluid for the differential?
The Haynes book list the Dana 80 between 6.8 and 10.1 pints.
I plan on jacking each side of the axle up while the cover is off in order to drain as much old oil as possible. How much lube should I expect to use?
Old Jun 20, 2005 | 08:48 PM
dezlsmkr's Avatar
Axle Application Engine Transmission Axle Oil Capacity Friction
modifier
Front 1500 4WD All All Dana 44 (216) 4.8 pts. NR
Front 2500/3500 4WD All All Dana 60 (248FBI) 8.5 pts. NR
Rear 1500 All All Corporate 9.25" 4.5 pts. 4 oz
Rear 2500 2WD V8 All Dana 60 (248 RBI) 6.3 pts. 6 oz
Rear 2500 4WD V8 All Dana 60 (248 RBI) 7.0 pts. 8 oz
Rear 2500 2WD V10, Diesel Automatic Dana 70 (267 RBI) 7.0 pts. 8 oz
Rear 2500 4WD V10, Diesel Automatic Dana 70 (267 RBI) 7.5 pts. 8 oz
Rear 2500 2WD V10, Diesel Manual Dana 80H Rear Axle (286RBI) 6.8 pts. 8 oz
Rear 2500 4WD V10, Diesel Manual Dana 80H Rear Axle (286RBI) 10.1 pts. 10 oz
Rear 3500 2WD All All Dana 80H Rear Axle (286RBI) 6.8 pts. 8 oz
Rear 3500 4WD All All Dana 80H Rear Axle (286RBI) 10.1 pts. 10 oz
LockedandLoaded
Jan 17, 2008 02:51 PM
rbrettctd
Sep 26, 2007 04:48 PM
Relentless
Oct 6, 2003 06:46 AM
BuckBoardDriver
Jul 3, 2003 07:30 AM
dingo
Mar 12, 2003 02:57 PM
