diameter of injector return line?
I have a 98 12v engine where the injector return line has been cut just before the filter housing. There is no longer a banjo connection. It has a hose slipped over it that has begun to leak. This is a daily driver, so I'm going a little crazy here!
What fittings are out there that will has a hose connection to that tube? AN would be nice but I'll go for anything right now. Slipping a hose over a tube doesn't seem permanent.
Many thanks
Edit: There is an aftermarket fuel pump with filters installed, the original filter housing is no longer there.
Many thanks
I'd go to a hydraulic shop or some place that carries compression fittings. Put a compression fitting on that goes to an 1/8" NPT thread, then you can get whatever hose you like made up.
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
