dangling vacuum line
Old Jul 6, 2007 | 10:42 PM
Cougsfan's Avatar
This afternoon I changed my fuel filter. While doing it I noticed a vacuum line hanging there not connected to anything. I looked all over for where it may go. nothing was obvious.
It comes out of the fire wall, up high just inboard of the brakes and sort of above the fuel filter. There are two lines there coming out of the same spot. One is a long one that goes under the drivers side battery (Cruse control?)
Any ideas where the other goes (Please tell me it goes to something on the cruise, 'cause it don't work.)
Old Jul 6, 2007 | 10:47 PM
tony597fitter's Avatar
That looks like the main one that goes to the vacuum pump. I am probably wrong on this, but take a look to see if the vac. line is hookes to the pump.
Old Jul 6, 2007 | 10:49 PM
Cougsfan's Avatar
Probably should tell you all it is a '96 1 ton. (need to put that in my signature huh?)
Old Jul 6, 2007 | 10:50 PM
Cougsfan's Avatar
Seems like I heard someone say the vacuum pump is on the back of the power steering pump?
Old Jul 6, 2007 | 10:55 PM
Yes it is. It is on the drivers side. Hooked to the back of the front case, with the power steering pump hooked to that. If that helps any.
You will see a nipple (if the vac. line isnt attached). The nipple is on a horizontal pointing toward the driver fender.
Old Jul 6, 2007 | 10:58 PM
Cougsfan's Avatar
Found it Tony, You were right. There is a big line that goes up to the brake booster, and it has a tee into that. Thanks.
Now if that was off from earlier, maybe my cruise will work now, or maybe I knocked it off when changing the filter. I am goin for a drive!
Old Jul 6, 2007 | 11:02 PM
That line controls ALL the vac. in the truck. So that means, if it was off, you wouldnt have 4wd, defrost only and no cruise.
Glad I could help.
jimbo486
May 8, 2016 06:07 PM
polarisman
Feb 10, 2008 02:18 PM
jfpointer
Dec 17, 2005 12:18 AM
NHDiesel
Sep 2, 2005 11:23 AM
Sidewinder
Jan 26, 2004 06:51 PM
