Curious trans temps
Old Jul 13, 2011 | 05:15 PM
R Walter's Avatar
Curious trans temps
Reference the No 1 truck in my sig with the DTT transmission.
I have an ISS trans gauge installed in the trans line leaving the transmission going to the cooler. When I'm pulling a load up a long grade my trans gauge begins to read warmer. That's to be expected. What has always baffled me is that when I'm under load and crest the hill on my way down the trans temps continue to rise. Seems like it should be cooling down, not rising. On a long pull (like uphill from Durango to Molas Pass on the way to Silverton, CO) with my 2,200lb Lance camper in the bed I see temps around 200* until I crest the pass and then my temps shot up to around 220* or so.
With no load the trans temps on the highway barely rise above the 140* mark, sometimes up to an estimated 160* - 170*.
Just wondering why the trans temp continues to rise somewhat when I'm on my way downhill???
Old Jul 13, 2011 | 09:42 PM
cj360trider's Avatar
id say its the fluid thats coming out of the TC on your way down the hill its still gonna be hot for a lil bit. im no trans expert so thats just my opinion mind you. i dont know for sure jus how quickly trans fluid cycles thru a TC
Old Jul 14, 2011 | 10:45 AM
9812vram's Avatar
X2
It'll take a little bit of time for the trans pump to empty the hot oil out of the heat-maker (torque converters convert diesel into heat lol) and refill it with cooler oil. Also, depending on what type of gauge you have, some of them take a bit of time to register, ie, the trans could already be that hot and the gauge just hasn't got there yet. Kind of like the fuel gauge when you fuel up. My tank's always full long before the gauge gets there....
davelinde
Apr 21, 2005 09:17 AM
davelinde
Mar 19, 2004 10:10 PM
williem
Jan 13, 2004 09:35 AM
apache
Jan 4, 2004 02:13 PM
Hired Gun
Jan 15, 2003 10:55 AM
