cruise inop
Old Jun 11, 2010 | 10:40 PM
skog8301's Avatar
cruise inop
ok the cruise was working fine up till a day ago. but today i hit set and it held the speed for about ten seconds then it just drops speed. it wont hold anymore. does anyone have any ideas.
Old Jun 12, 2010 | 08:56 AM
fschiola's Avatar
Put your foot behind the brake pedal and lift up. Then try the cruise control while keeping the upward pressure on it, if it works your stoplight switch needs to be replaced.
Old Jun 12, 2010 | 11:16 AM
kthiemann's Avatar
Another thing to check is the vacuum lines that run to it. They are bad about rotting out under the battery tray where the battery acid can drip on them.
Old Jun 12, 2010 | 12:02 PM
runningbird's Avatar
I just reconected a rotting line under the drivers battery tray yesterday...
check your lines.
Old Jun 13, 2010 | 08:44 PM
skog8301's Avatar
what battery tray are they under
Old Jun 13, 2010 | 09:08 PM
cmac's Avatar
drivers side. you have to pull the battery and the tray to get to it. there are two bolts you have to take out from under the truck.
Old Jun 14, 2010 | 10:18 AM
infidel's Avatar
I've always been able to replace the vacuum line under battery without removing the battery or tray.
Old Jun 14, 2010 | 02:03 PM
cmac's Avatar
i can reach it but cant see under there good enough to reconnect anything.
Huntsville 3500
Jun 22, 2009 02:11 PM
vanman59
Oct 6, 2007 07:31 AM
kas83
Sep 18, 2007 02:42 PM
max001
Jun 23, 2005 12:24 PM
I SPEED
Apr 10, 2005 10:15 AM
