Cruise control ?
Old Jul 1, 2008 | 09:12 PM
mm73's Avatar
Cruise control ?
Just wondering if anyone can tell me what to start looking for, I set the cruise control on my 95 dodge yesterday and it was working fine then all of a sudden it just stopped working. so I tried to set it again and nothing. I then checked the fuse and it was still good, so where do I go from here? I dont even know what color wired I should be looking for. Any help is appreciated
Old Jul 1, 2008 | 11:43 PM
Kansascrewcab76's Avatar
maybe vacuum hose is rotted or tps is out
Old Jul 1, 2008 | 11:53 PM
JonnysDodge's Avatar
Vacuum hose on mine was melted closed, I replaced and it fixed the problem, you can pick them up at any NAPA autoparts store for about 5 bucks. Good luck.
Old Jul 2, 2008 | 06:27 AM
mm73's Avatar
hey thanks guys where is this vacuum hose located under the hood and I will check it out
Old Jul 2, 2008 | 08:48 AM
blackimpala's Avatar
Check under the driver side battery. Acid finds its way down there and damages the C.C. lines and equipment.
Floyd
Old Jul 2, 2008 | 07:22 PM
mm73's Avatar
Thanks blackimpala I will check it in the a.m.
Old Jul 3, 2008 | 12:15 AM
also look on the cowl just to the left of the brake booster, hard plastic line with a rubber connector that turns to mush with underhood heat.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
