Complete 5sp Conv Notes!!
Old Dec 19, 2006 | 12:47 AM
  #46
~Angry Tractor~'s Avatar
So? Who's gonna do the 6 speed?
Old Dec 22, 2006 | 03:22 PM
  #47
Dazed&Confused's Avatar
Anybody else done this recently?
Old Dec 22, 2006 | 08:21 PM
  #48
2500's Avatar
subscribe ,,,,
Old Jan 19, 2007 | 09:28 PM
  #49
mx684's Avatar
I sure am glad i found this thread....this is exactly what i have been searching for , my auto is getting really bad, so ill be starting my conversion soon hopefully..
Old Jan 22, 2007 | 04:49 PM
  #50
lews930's Avatar
anyone know where I can get the trans and xfer case for this swap? these dodge autos are a piece of #%@#
lewis
Old Jan 22, 2007 | 05:04 PM
  #51
Cummins Freak's Avatar
yeah what a great thread this is what I'm going through right now to fix my auto or put in a man and also whether or not to even fix the dodge wrapper around the 12v and just put it in a different truck
Old Feb 23, 2007 | 05:32 PM
  #52
Box5's Avatar
maybe i'll end up buying a auto and just doing this swap.... i've seen a couple nv4500's for sale for 1500 or so, not bad considering how much 5spd cummins go for stock..
Old Mar 13, 2007 | 12:21 AM
  #53
Box5's Avatar
hey, I did end up buying a auto, lol. Just gotta get that 5spd in now.
Old Mar 26, 2007 | 02:13 PM
  #54
rustycarr's Avatar
2wd swap
im about to do the swap as well, my auto is gettin bad.. mine is 2wd, any wiring tips to make cruise control and neutral safety switch? can you just wire the nss together? thanks in advance. great thread.
Old Mar 26, 2007 | 04:10 PM
  #55
Box5's Avatar
I'm right in the middle of my swap, I can help alittle, I get most my information from lewis and peter on this site, lol...
For the wiring, to keep cruise control, Cut the plug off the clutch position switch (the 2 wires that are attatched to the clutch master cylinder rod that attatches to the cluth pedal) ground one of the black ones, then run the other black wire down to the new 5spd trans. The auto had a plug that had 3 wires (one for nuetral safety, the other two for the backup lights). Take the black/white nuetral safety wire and wire it to the black wire you ran down from the clutch posisiton switch. Then take the other 2 back up light wires and wire them to the nv4500 back up light switch on the top of the trans (take the plug off the trans to a hardware store and get a male plug that fits it to make wiring it easy). Thats all the wiring you need to do.
The speed control plug is on my transfer case so I don't have to touch that one, but you might for the 2wd trans, but I'm not sure.
Old Mar 26, 2007 | 06:41 PM
  #56
pete97's Avatar
Box5, I guess I have taught you well!!!!!!!!! LOL If I can still be of any help just let me know. Pete
Old Mar 26, 2007 | 09:03 PM
  #57
Box5's Avatar
LOL! Ur inbox probably has a entire folder just for questions from me,
Old May 11, 2007 | 06:40 PM
  #58
Originally Posted by RAPTOR01
Nice job on the details ..sounds like everything I did exept on the 98 I reused both drive shafts and on the RE auto all you have to do is the same as yours ..neutral safty switch/back-up lights. the only thing on mine is when you set cruise you cant disable it with the clutch ...bad thing it revs to the moon !!!!J-tec not set up for stick ....Chris
Ok I'm getting ready to do this on a 01 and need to know what I'll have to do wiring wise to get it to start. I'm not good with the diagrahms so if you all could tell me which wires and what I need to do it would be great. Mine is 2wd if that matters.
Andy
Old May 12, 2007 | 12:10 PM
  #59
Box5's Avatar
If ur puting in a nv4500 it's really simple. For the wiring, to keep cruise control and to start the truck, Cut the plug off the clutch position switch (the 2 wires that are attatched to the clutch master cylinder rod that attatches to the cluth pedal) ground one of the black ones, then run the other black wire down to the trans. The auto transmission had a plug that had 3 wires (one for nuetral safety, the other two for the backup lights). Take the black/white nuetral safety wire and wire it to the black wire you ran down from the clutch posisiton switch. Then take the other 2 back up light wires and wire them to the nv4500 back up light switch on the top of the trans (take the plug off the trans to a hardware store and get a male plug that fits it to make wiring it easy). Thats all the wiring you need to do.
Old May 12, 2007 | 05:44 PM
  #60
Hey thanks. Plan on starting in two weeks.
