clutch would not release
Old Sep 10, 2006 | 09:19 PM
brisnw's Avatar
On my 1998 12v, I was driving down the highway and went to shift to 4th, did not want to shift, pulled a little harder then shifter broke, pulled over to find that clutch was not totaly coming off, good pedal feel, lots of fluid, no leaks anywhere, put vice grips on shifter stub and started in 2nd and drove to town by power shifting, which part would fail more slave cyl or master?
I drove another 100 miles and now everything works normal again??? but I am sure something will fail soon
Old Sep 11, 2006 | 11:13 AM
gmctd's Avatar
First, hydraulic clutch systems are usually self-bleeding - it may not be the cylinders, but if one is failing, both will be at the same wear point, so replacing both master and slave is good preventive maintenance.
Second, problem may be the pilot shaft needle-bearing in the flywheel is binding up - you'll need to pull the trans, clutch housing, and clutch to replace that.
Old Sep 11, 2006 | 04:04 PM
halerazor's Avatar
get ahold of south bend they have a HD hydraulics kit slave and master for $250. usually if the hydraulics are going out the clutch pedal will not want to come back up.
Crossy's son
Nov 10, 2010 01:29 PM
93-12Smoke
Feb 20, 2010 05:25 PM
SeenTheLight
Mar 22, 2008 07:09 AM
robert chilton
Jul 31, 2006 09:36 PM
rsgstr
Mar 9, 2004 09:43 AM
