clutch master and slave
i think my clutch hydraulics are causing me problems. it doesn't look like you can bleed the system so are you suposed to buy the master and slave together? where should i go to get this stuff from? thanks
you just leave the lid off the resivoir and push the rod that goes in the trans on the slave. Once all the air is out, install the slave and pump the pedal.
You can buy them separately at autozone...it's cheaper that way
dieselboy59
Jul 25, 2010 12:32 AM
Fishbait
Jun 6, 2006 12:34 PM
