clutch/brake pedal assembly pin
Rolling up an onramp today, clutched it and felt a problem in the pedal and it didn't immediately go into gear, drove it home ~38 miles assuming I didn't have a clutch. Got home and looked, the pin holding BOTH clutch and brake pedal assembly lost a clip ring (for lack of a better term) and slid out to the right far enough to loosen the bracket. I had just a little clutch in the last two inches or so, but not enough to completely disengage. I didn't find any of the clip/keeper on the left side of the pin. I slid it to the right farther and took the right side pin off, for a sample. Does anyone have a factory maint. manual that shows the number of this pin keeper. It is not a complete circle, but pushes on a groove of the pin, and goes just over half way around the pin.
I lost one when I swapped out to the 5 speed and added the clutch pedal, its a common E-clip you can get at most hardware stores. I think there are some wave washers inbetween the mounts though, make sure you have all those.
Thanks guys. For future searchers dodge calls it the pivot shaft retainer. Idk that a standard 3/4" eclip is the exact size, seems a hair too thick, but that's what I used. Pin is a little loose, probably needs the bushing.
SRobertson
Oct 31, 2008 12:35 PM
