Clicking noise when turning only in 4x4
Old Apr 13, 2007 | 10:20 PM
caper's Avatar
When I test drove my 98 before buying I put in in 4x4 and worked great but never made any turns , It clicks bad when turning I'm thinking axle universals but wouldn't they make noise when in 2WD because they are still turning ?????
Old Apr 13, 2007 | 10:23 PM
DieselResearch's Avatar
I had that problem with my 94. It ended up being a combination of bad axle U-Joints, and an upper ball joint.
Old Apr 13, 2007 | 10:26 PM
Buckshotram's Avatar
Thats what im thinking too because from what I understand most of the front end still turns even in 2wd.
Old Apr 14, 2007 | 09:15 AM
wildmanben's Avatar
Front drive shaft u-joints will make that when they get worn. Mine did pretty bad.
Old Apr 14, 2007 | 09:37 AM
rattlerbob5.9's Avatar
Very posibly outer axle u joints and yes they do turn in 2wd they just arn't under load put it in 4 wheel and see if it is any different also check the ball joints and sway bar links.
Old Apr 14, 2007 | 11:19 AM
TxDiesel007's Avatar
I had the same problem
but i also found out that in conjunction to this, i had low T case fluid, i know its irrelevant but its worth checkin out as well....
Rick
Old Apr 14, 2007 | 02:24 PM
caper's Avatar
T case fluid is good , just changed it , it doesn't make the noise in 2WD that I can hear anyways , just in 4x4 when ya turn the wheel in either direction when driving. I have to get it checked out.
Old Apr 15, 2007 | 06:53 AM
Valv's Avatar
I have mine doing that too, very bad in 4x4, everybody stares at my wheel and make disgusted faces, I am buying few more days to nice weather to replace it.
While you have it off, check your brakes, if you need a brake job you might want to tackle it too since you'll have the hub off and that's where rotor is bolted on.
I'll have mine resurfaced, as might as well take advantage of the situation and fix anything needs fixed, it's not a quick job to take hubs off.
Old Apr 15, 2007 | 02:38 PM
rhino 660's Avatar
my t- case ic clicking it started to only do it while turning but has progressed to all the time while moving. the collar is slipping off the sync and i'm trying to fix it, ive had it out 2 time now!!
Timberman
Aug 18, 2010 02:46 PM
alltimelow1
Mar 29, 2010 07:26 AM
mnmlod
Jun 17, 2008 11:29 AM
Jambbii
Jun 6, 2007 10:40 PM
70DUSTER
Oct 8, 2003 10:29 PM
