Clearing codes on a 1995 12V
Old Jan 5, 2004 | 09:15 PM
Sidewinder's Avatar
I have a 1995 12V and I am wondering how to clear codes from the computer. I am getting a code 12 - battery disconnected, and a code 24 - throttle position too high/low.
I checked the TPS voltage and it was way too low. I adjusted it to 0.8 volts at rest but still have the code 24. Do I need to disconnect the batteries or should the code clear itself? I know the code 12 will clear itself after 50 key on/off cycles. Maybe I still need to increase the TPS voltage. I read here that the recomended voltage is between 0.8 and 1.2 volts at rest so I thought I would start at the lowest setting and work my way up.
Thanks!
Old Jan 5, 2004 | 09:52 PM
Crimedog's Avatar
To reset the codes,just disconnect both grounds for a while. I think that resetting it should take care of the code.
Old Jan 6, 2004 | 05:12 AM
infidel's Avatar
Can't remember the exact number but the codes also reset after 50-60 key on/off cycles.
deere nut
Dec 22, 2005 08:16 PM
jd03ctd
May 2, 2005 05:06 AM
Dieselcamper
Feb 12, 2005 03:08 PM
bigfoot
Aug 24, 2004 07:26 AM
