carier bearing
Old Jan 4, 2009 | 09:32 PM
oldblues's Avatar
Question carier bearing
hi
wondering if there is any way t o lube the drive shaft carrier bearing in my 98 quad cab .
want to take a 1500 mile trip in a few weeks and dont need any prob i can prevent with proper maint .
thank you !
Old Jan 4, 2009 | 09:40 PM
Yellow Yota's Avatar
Haven't looked into one, but I assumed it was a sealed bearing. If it is, there should be no servicing.
Look for a zerk fitting?
Old Jan 4, 2009 | 10:04 PM
BIGROD's Avatar
the 1 on my 2000 is sealed. I have a 172000 and still works fine
Old Jan 5, 2009 | 12:15 AM
1320's Avatar
fyi, I lost my carrier bearing on the road a few years ago. My 98 turned out to have a "special carrier bearing" I was told that 98's had a different bearing then almost all others I guess. I was told, only after getting the wrong one, that 98s have a larger carrier bearing then 97's or 99's. I dont know if its true, but I was sidelined for two days, and had a friend drive a few hundred miles with the right one just to get going again.
The dealer ended up doing the job for free, cause they felt bad about getting the wrong one the first time. That was the first 24 hrs....
Old Jan 5, 2009 | 05:38 PM
greg@Lockitup's Avatar
My center support bearing is a sealed unit. My carrier bearings are lubed by gear oil that is in the diff..
Old Jan 5, 2009 | 07:31 PM
BLAM!!! How could I have overlooked that one?!? I normally jump all over that kind of thing.
Old Jan 5, 2009 | 08:29 PM
Just from looking at your screen name I'd be willing to bet that you've had to deal with wore out carrier bearings that slide off of a yota 8 inch carrier by hand.. lol..
Old Jan 5, 2009 | 11:24 PM
Actually never had a problem with the carrier bearings. Beoken a few gear sets, but can't say why they failed. Other than too much abuse.
They make more of them every day!
Old Jan 6, 2009 | 06:41 PM
ha ha.. I've cleared off two 5.29 gear sets myself. The last set I cleared off I replaced with some Bobby Long cryo treat so we'll see how that goes..
Rattletrap1
Jul 11, 2007 12:12 PM
wadecool
Jan 12, 2007 11:39 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
mhuppertz
Nov 1, 2004 10:40 PM
