Can't hear turbo!
Old May 4, 2006 | 05:14 PM
speedster1858's Avatar
Can't hear turbo!
Hi,
I bought my truck last winter. This spring I opened the window while driving and heard the turbo whine for the first time. I loved it! Now I can't hear it. Where did it go?
Old May 4, 2006 | 06:10 PM
Teddy Bear's Avatar
Straight pipe it! Then get a different air filter! Thatll make er scream!
Old May 4, 2006 | 07:51 PM
blackdiesel's Avatar
Registered
this helps alot
is the silencer ring still in the turbo? do a serch on them, and youll find alot of info on it.
Old May 4, 2006 | 08:08 PM
TxDiesel007's Avatar
BHAF
and a gone silencer ring equal BOOYAH!! turbo whistle!
But if you insist on keeping the stock airbox, go ahead and pull the sleeve that connects the airbox to the passenger fender and it will have more air and you will hear more whistle..
Rick
Old May 4, 2006 | 09:40 PM
Abbynormal's Avatar
What Tx said, pull off the silencer ring and get a ScottyII intake, drilled through the firewall intake.
Old May 7, 2006 | 07:07 AM
Dodge@KY1997's Avatar
A friend of mine was saying that if you take out the silencer ring it could effect things because that is kind of a funnel that directs air into the turbo, w/o it the air wouldnt flow in as easy....Just wonderin...
Old May 7, 2006 | 07:29 AM
Forrest Nearing's Avatar
your friend doesn't understand how these turbos work then
Old May 8, 2006 | 08:23 PM
cody@nl'sCTD's Avatar
silence
yeah for real man pop that sucker out and listen to the results. this wont hurt ne thing. ive never had a truck with the ring in er and never had a problem.
Old May 10, 2006 | 08:56 PM
clarkoh's Avatar
Talking Glass Pack Muffler
When Warpspeed did my 4" exhaust, Dallas asked which muffler I wanted. How about the glass pack! Did I want the flutes or scoop things along the inner pipe of the muffler pointed towards the engine or away from it for less restriction. Uh, away! Nice mellow growl and you can hear the turbo at ALL speeds.
Old May 10, 2006 | 09:16 PM
bmoeller's Avatar
Yep. You won't find a silencer ring on a farm tractor or big rig.
Old May 10, 2006 | 10:20 PM
displacedtexan's Avatar
That unnecessary piece of scrap metal is a Dodge part, not a Holset part.
Old May 12, 2006 | 10:10 PM
obaja's Avatar
hahaha
hahahahah!!!! too funny!
Old May 13, 2006 | 08:37 PM
solid_st8's Avatar
I don't really understand why, but when I adjusted my valves today, they were all loose, my turbo came alive. I could barely hear it before, now it is definetly there. Could someone explain this. Thanks
Old May 13, 2006 | 11:38 PM
Maine69charger's Avatar
I would think that the loose valves affected valve timing and restricted the amount of air flowing through the motor. All of wich effected the efficency of the turbo. At least all the valves were loose instead of tight.
dennismorgan
Nov 15, 2013 06:59 PM
Micaiahfied
Aug 19, 2009 03:08 PM
klx300guy8
Mar 19, 2008 06:30 AM
bigwheels94
Jun 28, 2006 10:40 AM
Maverick2001
Jul 24, 2003 11:30 AM
