can't get to the plate
Old Jun 4, 2008 | 10:11 AM
winkle's Avatar
Here's a good read from "wiki" for tuning the 12v pump.
http://wiki.dieseltruckresource.com/wiki/Pump_Mod%27s
Old Jun 4, 2008 | 11:01 AM
Lil Dog's Avatar
Your are going to need to slide the AFC housing ahead as well or its not going to do much.. Also, you are going to need to do something with the waste gate. I used a hose pincher I got from a parts outlet for a couple bucks and then blocked it off. With the stock plate, you won't get to the 35 psi threshold for the stock turbo. Once you start changing the plate, you will need a better system.
Old Jun 4, 2008 | 11:06 AM
Keyser's Avatar
I thought you wanted to slide the afc housing towards the rear to make it even further from the plate.
Old Jun 4, 2008 | 11:12 AM
winkle's Avatar
Sliding the plate and the AFC forward means moving them towards the front of the engine.
Old Jun 4, 2008 | 10:18 PM
94DK107's Avatar
For the record, the method I read about w/the hand impact and torx bit didn't work. Ended up using a sharp chisel, making a groove in the side, and turning it that way. If you break the head off, no worries, just use vise grips after you get the AFC housing off like previously said. I couldn't get the slotted screw to budge before I hit it w/the hand impact, then it came out easy.
tyroneweaver
Jan 4, 2013 09:26 AM
Totallyrad
Jul 19, 2011 07:41 AM
Badd Dogg Guy19
Sep 8, 2006 11:48 PM
mr T
Jan 12, 2005 12:05 PM
