Brake light comes on in reverse
Old Apr 24, 2006 | 08:13 AM
tmacie's Avatar
So I've noticed a couple times that the brake light comes on when i out the truck in reverse (auto). I've felt nothing out of the ordinary. This morning I pull into work and go to back into a parking spot, i go to slow down and the pedal is hard as a rock....I give it more oomf and the truck did stop. Everything works fine when its in a forward gear, fluid level looks ok.....what could be causing this?
Travis
Old Apr 24, 2006 | 09:55 AM
infidel's Avatar
With vacuum assisted brakes it is totally normal for a hard pedal at idle, the vacuum pump just can't keep up. It only gives you two or three brakings before the vacuum runs out.
Old Apr 24, 2006 | 11:23 AM
tmacie's Avatar
This was an instant hard pedal....its never happend like this before. I mean I had to grab the wheel and pull to get the truck to stop. Its definatley not right....I understand the harder brake activation, but not this hard.
Old Apr 24, 2006 | 11:27 AM
Txwelder's Avatar
Booster going out?
Old Apr 24, 2006 | 12:48 PM
tmacie's Avatar
Could be, but why would it only happen in reverse?
Travis
hconstantino
May 3, 2010 12:15 PM
mr T
Jul 26, 2006 04:07 PM
benny852
May 31, 2006 09:04 PM
pittom
May 2, 2005 08:25 PM
John H
Aug 12, 2003 09:16 PM
