Brake and abs lights are on.
Old Aug 31, 2008 | 08:37 PM
BoDiesel's Avatar
After the ABS and brake lights came on I replaced the front pads, and rear shoes. The rear drums were out of spec so a few weeks later I replaced the rear drums. The front rotors are fine. A couple of years ago I replaced the wheel cyls with the Chevy conversion. My problem is that the ABS and brake lights are on. What do I have to do to correct this problem?
Old Aug 31, 2008 | 08:39 PM
mishkaya's Avatar
Usually it's the vehicle speed sensor that is bad. It's on the rear diff and costs less than $40 to replace I believe.
mishkaya
Old Aug 31, 2008 | 09:55 PM
muddindodge's Avatar
i have a 94 and mine was doin the same thing! right on top of the rear diff there is a sensor has two wires goin to it, replace that and your light should go out!
Old Sep 1, 2008 | 11:21 AM
BoDiesel's Avatar
Will give it a try, thanks.
Old Sep 1, 2008 | 11:57 AM
DodgeRamdiese01's Avatar
do the 24 valves have this same thing? mine is doing the same thing but mine is a newer truck thanks in advance
Old Sep 1, 2008 | 12:00 PM
mishkaya's Avatar
Yep, same thing.
mishkaya
Old Sep 2, 2008 | 11:28 PM
somis13's Avatar
I replaced the rear wheel speed sensor and my brake and abs lights are still on, its been 3 years now, I just put electrical tape over them on the dash.
Old Sep 5, 2008 | 08:51 AM
fahlguy's Avatar
Did you try the brake light switch under the dash?
Old Sep 5, 2008 | 10:31 PM
somis13's Avatar
yeah, wasted the 13 bucks on that as well
Old Sep 6, 2008 | 12:20 PM
Kim8839's Avatar
Try and reset it. Reset by disconnecting the negative battery cable and reconnect. If problem comes back then it is probably the abs sensor.
Old Sep 20, 2008 | 10:18 PM
dodge_kid9712's Avatar
mine were on for a while and i ignored it ( do not do this ) until my braken went out...needed to replace the hydroboost and the master cylinder
quadstar
Nov 20, 2009 05:23 PM
polaris800sp
Nov 13, 2008 05:35 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
