boost to high ?
Old Sep 6, 2010 | 10:58 PM
bwareofblksmoke's Avatar
boost to high ?
i have a 97 cummins and i tach welded the wast gate closed when i sWAPED IT INTO MY SUPERDUTY , and removed the vacume soliniod on the waste gate because of clearance issues , i ground the fuel plate to a #10, backed the star wheel all the way forward and the afc all the way forward , the truck is showing 65psi on stock turbo is that possible or is my used gauge a pos?
Old Sep 7, 2010 | 12:43 PM
Tate's Avatar
You running stock injectors? That sounds way too high for just a plate. I'd question the gauge.
Old Sep 8, 2010 | 12:03 PM
HammerMTB's Avatar
Put another confirmed accurate gauge on it to see, but drive pressure in that turbo is good for ~35 PSI. It will take a bit more breifly, but it will shear the shaft. 65 PSI will take that turbo out pretty quick.
ptgarcia
19
Apr 20, 2006 03:38 PM
Deer716
Oct 5, 2004 09:29 PM
BCarmicle
Sep 22, 2004 12:10 PM
klrmark
Sep 4, 2003 09:37 PM
