blow by
Old Nov 12, 2009 | 01:10 PM
ethang's Avatar
blow by
Does anyone know how to slow down the blow by on my '96 12 valve? It puts out quite a bit of smoke from the tube underneath
Old Nov 12, 2009 | 06:51 PM
infidel's Avatar
If you try to slow down the blowby it will build pressure inside the engine until a gasket or seal blows out.
If the blowby is excessive you need to find out what's causing it.
Could be as simple as a vacuum system leak or as bad as an engine that is worn out and needs rebuilding.
cfm3110
Mar 12, 2003 08:34 PM
DEZLPWR
Feb 14, 2003 08:40 PM
Iron Horse
Feb 12, 2003 10:51 AM
latitud_rt
Jan 1, 2003 12:41 PM
