Best Oil for a NV4500?
Old Sep 14, 2006 | 06:36 PM
Common's Avatar
I'm gonna swap out the oil... what should I run? (winter is coming)
Old Sep 14, 2006 | 06:53 PM
Captain's Avatar
from what I understand there is no best. There is only one kind thats approved to run in the 4500. castrol Syntorq® LT 75w85w. If you call castrol they will say only dodge can sell it to you. However I found it here http://www.quad4x4.com/NV4500%20Parts.htm for less then half the price of the dealer. Now I'm sure others will say you can run this or that and that they've done it for a while and its great. I'm not saying you cant run something else only that this syntorq stuff is the only factory approved oil so its what I use. Hope this helps you out some.
Old Sep 15, 2006 | 06:57 AM
displacedtexan's Avatar
GM also carries it, sometimes cheaper tha Dodge. It was cheaper by a lot at the Dodge dealer when I bought mine.
And yes, the SynTorque is the only approved fluid.
Old Sep 15, 2006 | 09:56 AM
infidel's Avatar
Using anything other than Syntorq (not Syntech) may get you by for a while but will come back to bite you in the rear 100k down the road no matter what the salesmen and people who have used brand X for ten thousand miles tell you.
Other oils are not compatible with the syncros and actually dissolve them over time.
Old Sep 15, 2006 | 10:07 AM
Pooter's Avatar
Syntorq.
All the way.
Got 253k miles on the stock nv4500
Still never gave up to the ghost, just became hard to shift, but still shifted when I pulled it(just was hard in 2nd, reverse)
Old Sep 15, 2006 | 01:36 PM
Hayseed's Avatar
That's what they say syntorque all the way but I've had very good luck with the AMSOIL tranny lube, except for that pesky 5th gear nut!
Old Sep 15, 2006 | 08:02 PM
RickCJ's Avatar
So if you had your tranny rebuilt and used the brass syncro's you can use whatever oil you want?
SilverSootXpres
Mar 23, 2010 07:18 PM
Elohim1
Nov 19, 2009 09:24 PM
primal13
Jun 16, 2009 09:01 PM
J Lent
30
Jun 15, 2007 12:42 PM
Lil Dog
18
Nov 1, 2004 05:34 PM
