battery-starter woes..
Old Oct 30, 2010 | 10:23 PM
GR40RCapri's Avatar
may have been covered previously, as I do remember others writing about the starter contacts (or something along those lines )
anyway, thought, for some odd reasons, my 1 yr old 800CCA PAIR of batteries were run low, after the truck sat for 3 weeks...
tried to start, and maybe one, or two cranks, then click click.
put the battery charger on it for a day. batteries reached 12.60+. Tried to start, turned over SLOWLY... again,
NO START
and REALLY pulls a HELLA load from the batteries. to the point where the charger is back to 60-70% output...
Thoughts?
my brother's 97 was experiencing the same, and with a new starter (his was too bad to rebuild...) it turns over like a mini-starter!
Thanks guys!!!
J
Old Oct 31, 2010 | 01:06 AM
Tate's Avatar
Whats the voltage like when cranking? Even if the batteries are relatively new, they could be bad. A load test should tell you if they are good or not.
Good batteries and slow cranking/no cranking, I had a starter that had the brushes that were completely worn out and had some serious pitting from arcing on the slip rings. Might be due for a rebuild.
Old Oct 31, 2010 | 07:15 AM
baddodges's Avatar
i agree with starter contacs they anly cost 24.00 dollars a cheap place to start,but i would have your batterie tested first.low batteries can cause damage to your starter.
Old Nov 3, 2010 | 05:45 PM
GR40RCapri's Avatar
Thanks guys..
so, if the starter is kicking the crap outta the batteries, it's probably not hi-resistance in the starter? probably batteries need changing (again.. 3rd set in 2 yrs....)
J
Spooler
13
Oct 24, 2014 08:33 PM
Mick-e
Jul 24, 2013 10:03 PM
gorms
Jan 29, 2007 05:05 PM
ramlovingvet
26
Feb 16, 2006 08:58 PM
Paradise Racing
Jan 18, 2005 09:08 AM
