Bad tps, going to POTS setup need help
Old Sep 10, 2010 | 05:54 PM
Crawlerhauler's Avatar
So I have been searching and searching but cant get a clear answer. If I convert to the potentiometer, will I need to manually ingauge converter, or just adjust my shift point and thats all?
I want to install this setup if I dont have to switch converter in and out. Please someone clearify!
Also can I put a switch in with it, to lock converter when coming down a hill?
Old Sep 11, 2010 | 07:59 PM
bigfatricky's Avatar
Potentiometer is just to adjust OD shift point.
TC lockup switch is an entirely different mod.
I just did both. Gotta be careful with the lockup switch. I already forgot to turn it off a few times while coming to a stop and holy jeepers does that make an awful racket. I can't believe that there wasn't shrapnel flying out of the trans. It is great for going down hills though. I assume I'll get better at remembering.......
Old Sep 12, 2010 | 09:24 AM
blackimpala's Avatar
There is a mod to wire in a relay on the brake switch to unlock the lock out switch when you use the brakes. I don't have the link.
Floyd
Old Sep 13, 2010 | 11:04 AM
infidel's Avatar
Old Sep 13, 2010 | 11:37 AM
Silver Ram's Avatar
I read a post a fe years ago where a guy had installed a pressure switch somewhere that disengaged the lock up switch before it downshifted into 1st.
Old Sep 13, 2010 | 04:37 PM
Just to clearify, if I install a potentiometer to replace tps. The converter will lock and unlock on its own and I can only adjust when it locks in.
If I want to lock it manually I can also install the switch.
Old Sep 14, 2010 | 12:42 AM
Maddog411's Avatar
Aren't you answering your own question from the original post?
Old Sep 14, 2010 | 01:00 AM
oldblues's Avatar
hi
love my preasure switch ,drop below 26 mph automaticly disingauges the convertor , speed up and it relocks !
no rembering to turn it off when slowing or stoping .
i would however like to be able to lock in convertor in 2nd gear as it only happends in third or od now , any body know how to do this ?
Old Sep 14, 2010 | 12:33 PM
Originally Posted by oldblues
hi
Ok so did the pot swap and it works great! As for manually locking for second gear, I ran a wire and tapped into pin 54 behind air box, then to a switch on my steering column that when turn on it just grounds it and locks the converter. That completely overides the computer and the pots setup.
Old Sep 14, 2010 | 05:07 PM
Maddog411's Avatar
The only problem with locking it up in 2nd is when it shifts to 3rd....it's hell on a tranny to shift with the TQ locked up.
whosdunit
May 17, 2014 08:54 AM
Chrisreyn
Jan 2, 2014 10:34 AM
eljefedavies
Apr 5, 2012 04:55 PM
fordassassin
Jul 17, 2009 12:22 AM
jrs_dodge_diesel
Feb 18, 2008 09:14 PM
