Bad sender???
Old Nov 25, 2004 | 02:44 AM
ChrisM55's Avatar
Question Bad sender???
Brother has a 98 12 valve and is doing some wiered stuff!! When at idle, cold and on an incline the oil gauge will go to 0 but then come back after a second or so, does this sound like the sending unit??? I searched back but did not find this symptom anywhere, but did find some close. I will get a gauge on so we can see tomorow but need some insight
Thanks,
Chris
Old Nov 25, 2004 | 05:18 AM
argve's Avatar
How about when it's sitting level?
How is the oil level? Incline or not she should be picking up oil and creating pressure.
Old Nov 25, 2004 | 07:23 AM
Dr. Evil's Avatar
Common problem......very likely the sender. Parts location diagram:
http://www.dodgeram.org/tech/dsl/Fac...ocations-l.gif
Old Nov 25, 2004 | 12:59 PM
ChrisM55's Avatar
there is plenty of oil, I had a feeling it was the sender but wanted another opinion before we dropped the cash
Chris
Old Nov 25, 2004 | 10:13 PM
Hemi Cat's Avatar
Sounds like a loose wire connection. With key on pull wire off sender, guage should go either up or down, then ground the wire and guage should go oposite direction. If good clean the connection and reinstall. make sure it feels tight , if not gently crimp the connector to tighten. Also check the wire harness for dammage. If it still irrattic, most likely a sender is failing. It wouldn't hurt to put a mechanical guage on it to verify oil pressure if problem persists. Good luck
Howard
Old Nov 26, 2004 | 09:41 AM
INJECTOR JACK's Avatar
My Dads did the same thing it was a bad sender his is also a 98
Old Nov 26, 2004 | 10:22 AM
sjester's Avatar
It can also be a PCM issue with the 98 12 valve, there is a TSB. Mine was doing the same thing except it would do it at any time. Computer reflash at dealer ($30) fixed the 98 12 valve I had.
Old Nov 26, 2004 | 05:31 PM
ChrisM55's Avatar
thanks again for all the input guys!!! Dusty's gonna change the oil furst and then go to the sender
Chris
Old Nov 26, 2004 | 07:02 PM
infidel's Avatar
Beware of generic auto parts senders, they don't last long.
You're better off spending more money just one time by buying one from Cummins.
Old Nov 27, 2004 | 12:11 AM
ChrisM55's Avatar
will do infidel
chris
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
Rabbit
Mar 31, 2004 08:15 PM
mcgyver01
Dec 29, 2002 10:31 AM
