Bad fuel economy
Old Oct 25, 2007 | 12:41 PM
lgp9999's Avatar
Bad fuel economy
I've been getting approximately 12mpg in town lately (unloaded). I just adjusted the valves to no avail. I have a new fuel filter, but due to the weather I have not had a chance to install it. I kind of have my doubts that this is the issue, as the truck doesn't seem to be lacking power at all (it should lose power before it should lose fuel economy, right?). If replacing the fuel filter does not solve my issue, where should I look next?
Old Oct 25, 2007 | 04:32 PM
Paul Winey's Avatar
Start with the filters. Both the fuel and pre-heater (easy to over look). http://www.dodgeram.org/tech/dsl/fil...filt_clean.htm
If that doesn't do it check the fuel pressure and over-flow valve. http://dodgeram.info/tsb/1996/14-07-96.htm
If that doesn't do it then think about bacteria in the fuel. I've had the same problem and am running the same fixes except I know the overflow valve and fuel pressure are good.
You may have to run a couple of tanks with a biocide additive to fix the problem then replace the fuel filter again.
Let me know how yours comes out. Good luck. Hope this gives you a place to start.
Paul
Old Oct 25, 2007 | 05:29 PM
wcbcruzer's Avatar
I get 12 too when I drive it to keep up with traffic from stops. Otherwise, usually about 14-14.5 if I accelerate slower. I think it's normal. I feel like I started getting 14 in town when I went back to stock tires from 265's. What kills the mpg is the factory torque converter.
Old Oct 25, 2007 | 05:47 PM
lgp9999's Avatar
Well, I've got a 5 speed and I was getting 17-18 in town for the entire ownership of my truck. This is definitely a new thing.
Old Oct 25, 2007 | 05:50 PM
Paul Winey's Avatar
My mileage dropped after I did the injectors so I thought it was that, but it has definately gotten worse even though it feels like it still has decent power.
Look at above causes and let us know.
Old Oct 29, 2007 | 11:13 AM
lgp9999's Avatar
Well, I changed the filter yesterday. I've put almost 17K on the truck, and who knows when it was changed prior to that (yes, I realize that it should be changed every 12k). There was a decent amount of junk in there. I took it for a drive afterward and it felt exactly the same as it did before. We'll see if my mileage improves.
Old Oct 29, 2007 | 11:25 AM
Paul Winey's Avatar
Time to check fuel pressure or just put a new overflow valve in.
Wouldn't hurt to put a bottle of biocide in just to cover that then check the filter after the tank is gone.
Keep us posted.
Old Oct 29, 2007 | 11:59 AM
lgp9999's Avatar
Where is the overflow valve located? Also, can I just go to any parts house and get biocide?
Old Oct 29, 2007 | 01:08 PM
Paul Winey's Avatar
Overflow valve and fuel pressure check here http://dodgeram.info/tsb/1996/14-07-96.htm
Check with local truck stops/service centers for biocide. Not sure of any specific name brands, sorry.
Paul
i12fsh
Aug 20, 2010 06:05 PM
coalburner400
50
May 19, 2008 12:19 PM
Txwelder
Feb 29, 2008 02:42 PM
C Pierce
Mar 21, 2005 08:41 AM
chrismez
Aug 9, 2003 11:48 PM
