bad block heater?
Old Dec 13, 2005 | 05:46 PM
tilyn62's Avatar
bad block heater?
Every once and a while the block heater on the truck will blow the breaker. So I was wondering if there is something wrong with the block heater or just step up ot a higher breaker if possible.
Old Dec 13, 2005 | 05:53 PM
Geico266's Avatar
Replace the $16 cord. PN # 251919 at any Cummins shop. It is pretty rare the heaters themselves fail.
If you need it fixed tonight replace the male plug.
Old Dec 13, 2005 | 06:30 PM
infidel's Avatar
Most times after a breaker has tripped several times the amperage where it trips gets lower.
Replace the breaker, even the same size breaker will often cure the problem.
Old Dec 15, 2005 | 01:06 PM
smokeyram's Avatar
Mine trips the RFI outlet constantly. Usually I have to go out and make sure the contacts are dry, any trace of water, and the RFI will pop.
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
Reelay
Dec 1, 2005 06:14 PM
