axle is shifted to the left
Old Nov 16, 2006 | 07:54 PM
somis13's Avatar
today I had my front end off the ground and noticed the whole front end was shifted to the drivers side. every thing is tight and I couldn't rock the axle housing at all. I noticed it by the sway bar things all cocked over. what could be wrong?
Old Nov 17, 2006 | 02:34 AM
Scramblinman's Avatar
The track bar is what controls lateral movement of the front axle. It could be worn or possibly even bent. Does your truck have any kind of lift? Lifting the front end without installing a longer track bar will also cause the axle to shift to the left. The higher the lift, the more the axle shifts left.
Old Nov 17, 2006 | 08:33 AM
RustyJC's Avatar
If the front wheels were off the ground (i.e., the suspension was at full "droop"), the Panhard (track) bar will pull the axle to the driver's side as the axle drops from its normal design ride height. A lift kit does the same thing if no correction to the Panhard bar is made.
Rusty
Old Nov 17, 2006 | 09:04 PM
somis13's Avatar
the truck had the lift when I bought it. so I'm not sure if a longer track bar was installed. I have noticed the drivers side of the truck always got more muddy then the other, so that would indicate the axle being shifted when at normal ride height. so a thuren track bar is the answer huh?
madhat
34
Jul 11, 2009 08:01 PM
04ctd
Feb 27, 2007 07:47 PM
Baja
Jul 24, 2006 10:15 AM
Big Wolf
Apr 26, 2006 11:02 AM
lyvwire
Jan 13, 2005 07:54 AM
