Axle Seal Leak
Old Aug 28, 2004 | 09:36 PM
DieselDaze's Avatar
Axle Seal Leak
Went out for a day of off roading and came back with bent steering linkage and an axle seal leak.
What is envolved in replacing the drivers front axle seal?
Rich
Old Aug 28, 2004 | 09:43 PM
pind's Avatar
Changing the driver's side seal is nothign too major, all you need is a little time, patience, beer, and a good understanding of colourful language.
Basically, you remove the both hub assemblies, pull the axles, remove the front cover, pull the differential assmebly out, change your seal, and re-assembly is the reverse of removal.
Most people say that you require a diff housing spreader, in order to get the diff back together, but in my experience, this has not been the case. Either I am really lucky, or there are easier ways.
Good luck in your axle seal quest, may the force be with you
Old Aug 28, 2004 | 10:11 PM
infidel's Avatar
Good instructions here> http://dieselpowerman.tripod.com/Fro...xle%20Tech.htm
DieselDaze's Avatar
Sounds like a good time replace the front diff cover with a nice aftermarket one!
Rich
supercharger
Feb 19, 2007 08:43 PM
jd03ctd
Jun 22, 2006 10:56 PM
DZLPWR
May 31, 2005 07:25 AM
dieseljerk
Jul 8, 2004 07:23 AM
Paul Winey
Jun 22, 2004 08:09 AM
