Autos worth looking at?
Old Mar 17, 2006 | 10:02 AM
CTDGuy's Avatar
I have found quite a few 12 Valves within my price range, I am going to be looking at some of them, but my question is. Are the 94-96 Automatics even worth looking at? I have heard horror stories about the automatics, should I even consider an automatic or what do I need to do to keep the tranny intact? I dont plan on BOMBing, maybe an exhaust and turn up the fuel slightly.
Any help is appreciated
Old Mar 17, 2006 | 10:04 AM
Mcmopar's Avatar
The Dodge 47RH/RE transmissions are really decent units. You could add a better TC and a VB and have a nice setup with the minor mods you mentioned.
Old Mar 17, 2006 | 10:10 AM
CTDGuy's Avatar
does the tranny say 47RH/RE on the side of it?
And arent TC's about $800.00? And I'm not sure what VB is
Old Mar 17, 2006 | 10:13 AM
marine4life's Avatar
94-95 was 47rh,96 on was 47re, both good units when set up right. depending on torque converters yes, they can be 800 dollars or even up to 16-1800. a valve body controls the where the fluid pressure is directed, thus controlling the shifting of the transmission.
Old Mar 17, 2006 | 10:14 AM
Mcmopar's Avatar
No, not stamped on it, 94-95 are the RH, 96-2003 have the RE. The "H" means it is a hydraulic unit, the "E" means it is electrically controlled. You can get a nice single disc unit from Dave Goerend for about 650.00 or so. The VB is the Valve Body, which is "basically" the brains of the transmission.
Old Mar 17, 2006 | 10:21 AM
CTDGuy's Avatar
Thanks for the quick replies! One more quesiton, If I do buy oe and leave it stock and do not much pulling, should I have to really do anything to it?
Old Mar 17, 2006 | 10:29 AM
infidel's Avatar
Thanks for the quick replies! One more question, If I do buy oe and leave it stock and do not much pulling, should I have to really do anything to it?
Even with power mods up over 350 hp at 4k my stock RH went 212k before I replaced it with a complete Suncoast. Even then nothing was really wrong, I just happened to have the money and didn't want to tempt fate. It all depends on how you drive, personally I rarely smash down on the go pedal. Your disadvantage is that you don't know how the previous owner treated it.
Racers prefer the RH tranny over the RE.
Old Mar 17, 2006 | 10:30 AM
CTDGuy's Avatar
I really appreciate it guys, i'll take this into consideration tonight when I look at this thing, 94 Reg Cab, 88,000 miles for 9500.00... we will see how things go
Old Mar 17, 2006 | 10:31 AM
CarlJensen's Avatar
Get it serviced (fluid and filter) and put synthetic fluid in it. If you have a light foot and don't tow heavy you should be OK.
Cold Diesel
Dec 6, 2004 04:16 PM
Officer Al
Nov 13, 2004 04:32 PM
LanceD
Oct 15, 2004 01:12 PM
crankbait
Jan 16, 2004 12:25 PM
st_pinetree
Apr 13, 2003 07:59 AM
