Auto shift lever stiff
Old Oct 20, 2006 | 01:53 PM
Ironstone's Avatar
The shift lever on my truck is geting really stiff. It doesnt slide from Park into RNDL very easy at all. Anyone else have any problems with this before? I could use some pointers. Thanks.
Old Oct 21, 2006 | 07:26 AM
Ironstone's Avatar
Bump, bump....
Old Oct 21, 2006 | 03:58 PM
mitch@jc'sCTD's Avatar
Mine is stiff leaving park but then is sort of loose once its out of park.
Old Oct 23, 2006 | 09:38 PM
mysterystench's Avatar
Anyone got any ideas? Mine's the same way...
not really a problem, just somewhat annoying..
Old Oct 23, 2006 | 10:06 PM
88bird's Avatar
look at the shift lever setup below the drivers door under the truck inside the frame rail IIRC..... there are a series of levers/springs that connect to the tranny.... use some good ole PB blaster and soak it good..... or just clean all the dirt away.....
Old Oct 24, 2006 | 12:01 AM
Fueling around's Avatar
Park is only meant to lock the tranny. Try using the park brake to hold the truck,
I notice if parking on a hill and only using the parking prawl (park gear in trany) it is vert hard to shift out of "P".
DodgeCowboy
Mar 8, 2015 11:29 AM
kas83
Aug 2, 2009 09:23 AM
MoNStrRIg
Sep 13, 2008 10:47 PM
Tuckerdee
May 27, 2005 04:04 PM
