Anyone know the Cummins number for the delivery valve washer?
I'm setting my timing and want to buy the washer. Anyone know the Cummins number so I can avoid getting ripped off at the Dodge dealer?
Bob
Bob
I just got off the phone with Diamond Diesel in Oakland and he said that the 1997 pump doesn't have a copper washer. There is an o-ring that is there to keep dust and debris out and that it it.
wait I lied
The delivery valve gasket can be either bronze or steel, or on new injection pumps, there is often no gasket.
If the gasket is bronze, use a pick to remove it from the top of the pumping element; if the gasket is steel, use a pick or a magnet. Discard the used delivery valve gasket.
nspect the fuel injection pump bore for debris. The bore must be free of debris.
If a gasket was removed from under the delivery valve, install a new delivery valve gasket (Cummins Part Number 3824567) into the fuel injection pump. Do not use a gasket if this is a pump with gasketless delivery valves. See attached list of pumps that have or do not have delivery valve gaskets.
Delivery valve socket and a torque wrench. A magnet works good for getting the DV's out, but needle nose pliers will also work. Once you get the old ones out, reassemble and torque to 90 ft-lbs.
Swamp_Donkey
May 14, 2003 09:31 AM
