Any tricks to removing upper control arms?
Old Oct 16, 2010 | 04:19 PM
Hodge's Avatar
I just bought a set of polyurethane bushings for my control arms. I started looking it over today, and it looks like the upper control arms are confined on both ends. Is there more room in there to move things around and extract them, or do I have to get the axle forward enough to fish them out?
Old Oct 17, 2010 | 05:50 PM
Hodge's Avatar
I figured it out.
Now to get the sleeves and old rubber bushings out.
Old Oct 17, 2010 | 10:57 PM
FlaCracker's Avatar
I just did mine today. I just used a drill and drilled multiple holes in the rubber bushings and then just ripped pieces of the rubber out til I could get the inner sleeves out. Once you get the inner sleeves out, the rest of the rubber comes out easily. I left the outter shells in the arms, no way they were coming out without damaging them. You can get it, just takes some work!
Old Oct 17, 2010 | 11:09 PM
Purplezr2's Avatar
I did like the person above, just drilled a bunch of holes around the bushing, then peeled what was left out. Worked great.
Old Oct 20, 2010 | 11:27 AM
esde's Avatar
What bushings did you get?
Old Oct 20, 2010 | 03:37 PM
Hodge's Avatar
I bought a set or Prothane urethane bushings off of Ebay. The kit came with new bushings, sleeves, and grease. $85 delivered to the door.
I once bought a set for a 95 Jeep Wrangler for $20. The seller never got the time to install them. To bad he didn't buy a Dodge after his Jeep...
Old Oct 21, 2010 | 03:09 PM
Hodge's Avatar
The job is done. Drilling out the bushings worked fine. Thanks for the advice.
02ctd4now
Jul 4, 2008 05:05 PM
TRX24V
Nov 22, 2007 09:08 AM
95black2615
Sep 1, 2007 08:58 PM
wcbcruzer
Aug 2, 2006 12:54 PM
JWBartel
Jul 14, 2005 09:39 PM
