Crank sensor problems??
Old 12-18-2017, 06:42 PM
Waz
Waz's Avatar
Lost charging,ac,Speedo. Cps was chewed up on bottom put new sensor on still nothing. Changed pcm still nothing. Checked cps wires at pcm don' have 8 volts at tan/yellow wire. All 3 wires ohm. What to do now?
Old 12-18-2017, 07:35 PM
patdaly's Avatar
What air gap did you set? Factory calls for .049/.051 but many of us just use a folded business card for a gauge.
Old 12-18-2017, 09:49 PM
torquefan's Avatar
Check a wiring diagram to see what else that tan/yellow wire feeds. Another sensor could be shorted out and driving that circuit to ground.
Old 12-19-2017, 07:44 AM
Waz
Waz's Avatar
gap is set at .050
Old 12-19-2017, 07:47 AM
Waz
Waz's Avatar
Thinking about splicing in on the ground wire from sensor grey with black tracer if I remember right. And see if I get anything that way. Thoughts on that?
sjester
05-10-2007 05:03 PM
Gabe32
16
02-22-2007 06:37 PM
aaronedwards82
01-14-2007 09:07 AM
PaulDaisy
12-02-2006 12:36 PM
kingofdodge7131
05-24-2004 01:09 PM
Quick Reply: Crank sensor problems??
