Another click / tick question.
Old Feb 14, 2008 | 02:18 PM
DRam11's Avatar
I thought of posting this on the thread below dealing with strange noises, but decided that would be tantamount to hijacking the thread. Maybe not, both might be realated. Anyway, my '97 has a ticking/ckicking noise, and something that sounds suspiciously like a miss. There is no feel of a miss, as near as I can tell the engine pulls smoothly throughout the rev range. Using a stethescope one can hear the noise most clearly when on the fuel line to #1 injector close to the injector. As you get farther from the injector the sound is fainter, it can be faintly heard at the injector pump. The click can be heard, but not as loudly, on the injector body, on the head and faintly on the valve cover. The click cannot be heard anywhere else. What are the chances the noise I'm hearing is a bad injector?
Old Feb 15, 2008 | 04:12 PM
dozer12216's Avatar
Not very good based on your description. If really want to presue, swap with another injector on engine.
Old Feb 15, 2008 | 11:05 PM
DRam11's Avatar
Thanks, I'll try that. Any idea what else I should check?
Old Feb 16, 2008 | 06:52 PM
fschiola's Avatar
Have you completely ruled out a valve out of adjustment? Run an overhead and see if that clears up the noise. Click here for instructions.
Old Feb 17, 2008 | 05:35 PM
DRam11's Avatar
Checked the valves once and found the #1 intake loose. Resetting it didn't affect the clicking noise. Thanks for the valve setting instructions.
MTC
Jan 2, 2008 07:53 PM
stirpicult
34
Nov 15, 2007 08:50 PM
marksmith
Aug 17, 2007 02:57 AM
59FORD
Aug 10, 2005 08:09 AM
haulywood
Jun 10, 2005 11:27 PM
