Alternator problem?
Old Feb 29, 2008 | 06:42 PM
Redneck_King's Avatar
Alternator problem?
I have been having some power issues. More specifically, it seems as if my alternator is not charging my batteries as much as it used to. But if i ignore it for a couple days, it goes away. Another thing is that my truck is running hot, about 100-200 degrees hotter EGTs than normal. Could my grid heaters be on constantly somehow or am i way off the map?
Old Feb 29, 2008 | 10:59 PM
dozer12216's Avatar
Common issue with Alt is brushes. Most alt/starter shop has in stock and easy to install. Clean slips rings at same time. Have alt tested free at friendly parts store while its off. This beats on vehicle testing. Check batteries separatelly also. You got to have power to start.
Could thinned down fuel be causing your EGT issue? It's cold up there and fuel must flow.
Might be getting time for starter contacts also.
5.9Excursion
Mar 13, 2008 07:08 AM
bigredbrick
Nov 8, 2006 12:18 PM
jnnmillwood
Sep 11, 2006 10:33 PM
emcconne
May 1, 2006 11:40 PM
Ron
Jan 24, 2005 09:29 AM
