AFC housing bolt
Old Aug 27, 2006 | 09:42 AM
9512vCTD's Avatar
Can you extend AFC housing hose?
I am putting a shut off valve in-line in the hose that people pinch off to disable the wastegate that way i can have it off on or partial. I was curious if it mattered the length of the hose running from the housing to the hard line under the intake. Reason i ask im going to make a loop to allow room for a inline valve and just was wondering before i did this. Right now the hose is maybe 7 inches long i would probly make it 11 inches or so long with the loop.
thanks
garrett
Last edited by 9512vCTD; Aug 27, 2006 at 04:12 PM. Reason: Question asked didnt want to make repost
Old Aug 27, 2006 | 11:10 AM
TxDiesel007's Avatar
Originally Posted by 9512vCTD
I need a new bolt in the afc housing i had a few i bought and can't find them and its nice out so a good day to replace it was a little metric can't seem to search and find the bolt size.
Thanks,
Garrett
The screws in your AFC housing are M6x1.0 -20 on the engine side and m6x1.0 -25 on the fender side, the ones that go into the fuel shut-off bracket. You can also buy a set of hex bolts that will fit in there too..
Rick
Old Aug 27, 2006 | 12:38 PM
pete97's Avatar
I was told that the small bolts closest to the engine were 6mm x 1.0 x 18 and the longer ones were 6mm x 1.0 x 24.
Old Aug 27, 2006 | 01:03 PM
Might be correct
that reply is from one i got about a year back when i first started to mess with my AFC and plate and so forth. So i just reposted it. I run my assembly without the break off screw and have had no problems with leakage or anything else. Im also missing the 8mm screw that holds the shutdown solenoid from the rear...
Rick
Old Aug 27, 2006 | 03:02 PM
infidel's Avatar
I use the size Pete posted. Prefer the allan head type, easy to get at.
Old Aug 28, 2006 | 11:32 AM
pete97's Avatar
That's what I use too, The allen head screws. They work better.
West Coast
Feb 6, 2012 03:19 AM
Saggy
Aug 12, 2006 09:05 PM
Jeremy Cusick
Aug 7, 2005 03:16 PM
royta
Feb 15, 2005 10:15 PM
halerazor
Jun 14, 2004 08:45 AM
