AFC Housing allen bolt stuck?
I am trying to get a little more low rpm power out of my tuck,so I tried adjusting the starwheel.The 8mm hex bolt is stuck!I have a 12" Crescent wrench on the allen wrench and still no go.I am afraid I will break something.I have lightly tapped allen wrench and drenched bolt with crc56.The only thing I can think of is to get a 8mm allen socket and connect to 1/2'' drive ratchet.Any suggestions before I wreck something?Truck is a 96 2500 12 valve 215 pump.Man I miss my simple gen. 1.
I had to work on mine for most of a day before I finally got it to move. Used much Deep Creep (Seafoam) and a big wrench on the allen persuaded with a hammer!! The same gorrilla that installs filters put in that allen bolt!!
Mine came loose with a loud POP. I used a 3/8" drive allen socket from a brake kit to get it loose and a box end wrench used as a cheater. When I put it back on I didn't get it that tight. If it's never been off you may be trying to break the paint as well.
I did the same thing the first time
the 3/8 ratchet with some extensions and the 8mm hex key plug along with three feet of cheater square tubing. One loud pop later it came off...
Rick
I have had mine on and off several times, each time it is hard to break open. I think what is going on is that there is disimilar metels between the housing and the hex bolt.
Vintage Empire
Jan 23, 2006 07:34 PM
halerazor
Jun 14, 2004 08:45 AM
Why would you tighten something of that material so much?
Is it worth the effort performancewise?
