Adjusting the idle
Old Apr 1, 2004 | 01:30 PM
Yamadad's Avatar
Adjusting the idle
I need to adjust my idle speed. I have the factory manual and they make it look sooooo easy. BUT, when I actually look at the truck, it is totally a different story. I can't even see it, let alone reach it. Any tips?? Other than a partial disassembly of engine and components.
Old Apr 1, 2004 | 02:27 PM
infidel's Avatar
Maybe this will help-
http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Old Apr 1, 2004 | 06:31 PM
turbo thom's Avatar
When you reach in under the rear of the pump, feel for the lever where the spring is attached and you will feel a 10mm nut over a sloted screw. Loosen the nut and with the left hand push the linkage back to take the pressure off. Then you can turn the screw with your fingers. It dosen't take much to make a big difference. It's not like adjusting the valves. The screw will stay in place while you shug the nut.
That's it.
..Preston..
Old Apr 2, 2004 | 05:44 AM
Bad 6X6's Avatar
I had to remove the screw and file it flat again before I could adjust the idle. It had a grove worn in it and when I moved it would change it too much. It was easy.
FlaCracker
Oct 23, 2009 02:42 PM
trophystock
Aug 3, 2006 12:23 PM
NoSparkplugs
Nov 3, 2005 10:43 PM
Dr. Evil
16
Oct 10, 2005 05:14 PM
FIREDUDE
Mar 18, 2005 11:31 AM
