abs light on after motor and axel swap now no O/D?
Old May 4, 2009 | 10:50 PM
heykw's Avatar
is the O/D hooked up with the abs some how?
p.s. I tried to us search and kept getting an error.
Old May 5, 2009 | 08:59 PM
rstrucks's Avatar
Does your speedometer work? I know some vehicles use the rear abs sensor for the road speed input. Is yours hooked up and functional? And yes, road speed does affect OD operation.
Old May 5, 2009 | 10:45 PM
heykw's Avatar
yes the speedo works.
Old May 6, 2009 | 09:06 PM
heykw's Avatar
Help?????????????
Old May 6, 2009 | 09:44 PM
HotRodTodd's Avatar
You swapped the motor right?
Which ecm did you use? If you used the ecm from the swapped motor, did it have a manual or auto trans?
Old May 6, 2009 | 09:49 PM
HotRodTodd's Avatar
BTW, I am in Port Richey, about 2 1/2 hours from you. If you need a hand, pm me your ph.#, I am at the shop working, so I will be here till about 3am.
Old May 8, 2009 | 02:01 AM
Mud_Duck_Diesel's Avatar
Yes, the O/D function can be effected by a brake system problem. Could be anything from an unplugged ABS sensor to a brake light switch. Certain conditions must be met for the o/d unit to engage and converter lock to occur. If the system senses a problem (or it thinks your foot is on the brake), it won't let it happen. Hell, some years wont let the RPM's climb unless your seat belt is latched... Gotta love Chrysler products.
BigBore050
Mar 9, 2010 11:46 PM
heykw
May 7, 2009 10:06 AM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
JImbo1
Apr 9, 2003 07:46 AM
